Special switch
Old 06-07-13, 10:35 AM
C
Lightbulb Special switch
I was curious if the switch I'm thinking of exist and what the name would be called so I can order one. Ok here's what I want to happen:
Example
I want a switch that will connect a circuit when 5v (or 12v) power is running to it then when the 5v power has stop running it opens the connection.
5v power on {12v Battery}-----------------------[Light on]
5v power off {12v Battery}-------- /-------------[light off]
Looking for cheap like a small circuit board or something.
Thank you
Old 06-07-13, 11:31 AM
W
Received 1 Upvote on 1 Post
Use a relay. When power is applied to it's coil it will switch the contacts to turn light on by hooking lights to it's normally open contacts.
Here's a link to some relays with 5 and 12 VDC coils.Relays - Sensors, Switches & Relays from Allied Electronics
Old 06-07-13, 12:52 PM
F
Depending on the load (size of the lamp bulb) you may find a suitable relay at your local Radio Shack.
Old 06-07-13, 03:03 PM
C
Thank You!
I think that will work perfectly awesome! Thank you for the quick response too!
