Wiring Two Lights to One Timer
Received 0 Votes
First, I would like to thank all the contributors to this forum for sharing your vast knowledge. I read the forum daily and am learning a tremendous amount.
I have an overhead light and two wall sconces illuminating my front steps. The overhead light and the sconces are on separate, adjacent switches in the same receptacle. They are also on the same circuit. The wall sconces are controlled by a digital timer. I would like to add the overhead light to the same digital timer. Can I simply connect the switch wires controlling the overhead light to the leads (black and red) from the digital timer that are controlling the wall sconces?
I am not at all concerned about exceeding the wattage rating of the timer. All three fixtures have small LED's.
Thank you all in advance for your input.
Received 0 Votes
Ray, the switch, I wish to "piggyback" on the timer has two black wires. I will have to check this evening if there is a bundle of white wire in the box, but I do not recall seeing any.
Thanks
Thanks
Look carefully at the two black wires on the switch? Is one of them a pigtail? If so that one will be completely removed and the other switch wire added to the power out side of your timer.
Nash has brought up a point I didn't consider. I assumed a lead on the timer not screw terminals. See Nash's post below. What my minds eye was seeing when I wrote my reply was a black lead to the sconces wire nutted to the wire from the switch. The overhead light would be added to that wire nut. If you have screws I can unstand I was not clear.
I eliminated the pigtail and connected the other black to the power of the timer. The overhead light does not come on when the wall sconces are on
Id your timer came with lead wires instead of screw terminals you won't need the pigtail.
