Pool Timer - turns off and stops
Old 06-10-13, 05:08 AM
Intermatic T104
Run ok turns ON and turns off at correct time.
Stops when it turns off.
I reset the clock time it does the same the next day.
any ideas?
Dave
Old 06-10-13, 06:40 AM
You have it wired backwards. If you don't hook up the "from breaker" and "to pump" wires to the correct terminals, the clock motor's leads end up connected to the load side of the switch, and therefore loses power when the switch turns off.
Assuming this is a 240v unit, the incoming line should be on terminals 1 & 3, the outgoing line to the pump should be on terminals 2 & 4.
Old 06-10-13, 07:54 PM
OK I will give it a try.
Why does it work sometimes?
Thanks
Dave
Old 06-10-13, 08:10 PM
Nashkat1's Avatar
Change the wiring to be connected the way Matt suggested.
Old 06-10-13, 08:22 PM
Is this an old timer (been working ok for years) or one you just installed ?
Old 06-11-13, 04:14 AM
I did change it.
Thanks
Dave
Old 06-11-13, 08:52 AM
I did change it.
You changed the timer or changed the wiring ?
If the wiring ..... was it incorrect ?
Old 06-11-13, 09:42 AM
Changed the wiring like JersyMike said.
I will let you know if it works this afternoon.
Dave
Old 06-11-13, 09:45 AM
It's Matt, not Mike...
Old 06-11-13, 07:55 PM
It worked ok is still running.
Thanks
Dave
Old 06-12-13, 08:11 AM
Nashkat1's Avatar
Glad you got it working. Thanks for letting us know.
