Need some advice on a MWBC
Received 0 Votes
Hello everyone, Long time lurker first time poster here.
I am doing a retrofit of some florescent lights and some outlets and need some advice.
I have removed all of the existing fixtures and replaced with recessed cans. So that part is done and completed. However i need some help thinking through the existing MWBC.
(this is all 20amp by the way)
There is a junction box in the ceiling that has an MWBC in it. One half (red) fed the florescent fixtures which i used to install the recessed fixtures. The other half (black) was used to goto a receptacle in the ceiling. I capped this black wire originally and am now wanting to add more receptacles off of this black wire and a shared neutral.
I have a diagram of the circuit. Could someone take a look and let me know if this is legit? The breakers are installed in a Square D box single phase numbers 2 and 4 so they are on opposite poles. From my understanding of MWBC this is ok as long as the handles are tied or i convert it to a double pole...
Any advice is appreciated.
It looks to me as if you don't need GFCI or AFCI units but if you did, you can install them on one or both sides of the circuit after the circuit splits apart (at the middle junction box as shown) and no special treatment is needed.
If you wanted to install a GFCI or AFCI unit in the panel, the unit must be for a MWBC (for a 120/240 volt circuit).
