240v at breaker. 78 v on other end of lines.
Old 06-17-13, 09:10 AM
I need this explained : attic air handler needs 240v. I have double pole breaker reading 120 to ground each leg and 240 across. At other end of lines i also have 120 to ground each leg but only 78 volts between legs. Do i have a compromised line after breaker?
Old 06-17-13, 09:14 AM
There is no junction box between breaker and handler. Just lines from breaker go right to unit.
Old 06-17-13, 09:18 AM
Welcome to the forums.
If there is no splice point then it appears you have a defective piece of wire.
Possibly compromised with a nail or cut in some other way. Wire very rarely goes bad by itself.
