instead of pigtail come off of receptacle
Received 0 Votes
I came across this diagram on the internet and i was wondering if instead of pigtailing the hots and neutrals if i could just connect both neutrals to the receptacle and connect the feed to 1 brass terminal on the receptacle and then run a wire from the other brass terminal to the switch.
Would this be considered acceptable or would pigtailing the wires like this diagram be what should be done.
Thanks.
Thanks.
Yes.....you could do it the way you are asking about.
The reason we as electricians use the pigtail method is to eliminate wiring confusion and ultimately since the connection is not relying on two screw terminals for continuity.....it's more reliable,
