Need review of my plans - sub panel at shed
Received 0 Votes
I want to put a sub panel on my shed that will run a 1hp 10amp double insulated pool pump (std 3 prong plug), and a convenience outlet (for above ground pool).
My plan:
Already dug a 20inch trench (my god that was a nightmare)
Put in a 60amp 2 slot 4 circuit box
Put in a 20amp for the pump
Put in a 20 amp for convenience (I could go bigger on both but its overkill already)
Run four 6 awg wires in a 1 inch electrical PVC conduit (individual with sheathed wires). The run is approx. 100ft
Put in a 60amp double breaker at the main panel
Does that cover the basics of adding a sub panel? I am concerned about the gauge and if there is any code specifying conduit size (1 inch seems plenty).
Additionaly, I am going to try to bring it up right under the main panel. My house is newer and all electrical is run from ceiling which should make the bottom clear. If I have to run it horizontally, what interior conduit is to spec? Does the liquidtite non-metallic flexible conduit meet code?
Thank you very much. I tried to do my homework before bugging you guys.
My plan:
Looks good.
You can run a #8 for ground instead of #6.
Be sure to run THWN wiring as it's in the presence of water.
1" conduit is good.
I would put in a ground rod at the sub panel location connected to panel with #8 wire.
Remember at the sub panel you will need to keep the neutrals and grounds separate. The panel should come with an insulated neutral bar. You may have to purchase a grounding bar.
It's looking like your loads will be 120 volts. You will need GFI breakers or receptacles.
1" conduit is good.
A 60 amp feeder is way more than you need. YOu could save some money and install a 30 or 40 amp feeder.
You cannot install overcurrent protection greater than 20 amps for standard receptacles.
Any receptacles outside will need to be marker WR for weather-resistant in addition to the in-use covers and GFI protection. You will also need to keep the receptacles the proper distance away from the pool.
The ground for the pool circuit needs to be insulated.
Received 0 Votes
Thank you for your help. I purchased everything yesterday, and it was painful (more than I expected).
My shopping generated a couple new questions.
I purchase a panel, timer, and receptacle. What conduit can I run between the 3 boxes?
I also need to put in a ground rod. I was told that the code requires 8 feet. There is no way on this earth I will be able to get 8 feet of rod vertically into the ground. Are there other options (burry it horizontally)?
PVC conduit is easy to work with. Depending if physical damage is an issue you might not even need conduit.
(G) Rod and Pipe Electrodes. The electrode shall be installed
such that at least 2.44 m (8 ft) of length is in contact
with the soil. It shall be driven to a depth of not less than
2.44 m (8 ft) except that, where rock bottom is encountered,
the electrode shall be driven at an oblique angle not
to exceed 45 degrees from the vertical or, where rock bottom
is encountered at an angle up to 45 degrees, the electrode shall
be permitted to be buried in a trench that is at least 750 mm
(30 in.) deep. The upper end of the electrode shall be flush
with or below ground level unless the aboveground end and
the grounding electrode conductor attachment are protected
against physical damage as specified in 250.10.
Received 0 Votes
I wasn't sure if I could use PVC. I know the panel has to be grounded and I wasn't sure if all the other enclosures have to be grounded as well using metal conduit of some sort between them.
I guess I will see how far the bar goes down using an impact hammer.
If it doesn't go down far, I can dig a 30 inch trench and cut the rod up into equal segments and burry them in the trench vertically and use a continuous ground wire #8 to connect the rods to the panel?
I have some really hard soil. Digging the 20 inch trench for the wire as a nightmare.
I appreciate all your help. Its hard to research this stuff. Is there a website that allows you to search the NEC code by keyword?
I am not going to get into bonding yet. My pump is double insulated and the pool has vinyl top rails and verticals. I am not sure what I could bond it to. I think the pool manufacturers are building pools that make parts of the code unnecessary.
I think its a solution looking for a problem. I would wager you couldn't find a single injury due to a difference in ground potential. GFI(s) prevent the majority of electrical related pool deaths (60 or so in 13 years, many of those were from shock outside the pool or didn't have GFI).
EMT can not be used for direct burial. Cable can not be used for pools.
Received 0 Votes
Pick the spot and lay a 3/8" washer on the ground. Set the tip of the ground rod in the center of the washer and start driving. My go-to tool for driving the rod is my 16 oz. claw hammer.
The water on the pool will get bonded. There are bond fitting made to do this.
I am still considering whether or not I will bond the metal on the pool and water. I see it as a solution to a problem that doesn't exist in an above ground pool. What does it solve? There is no electricity coming into contact with the metal or water, the pump is double insulated. As for "ground potential differences", it would be rare indeed that there is enough difference in ground potential to cause injury.
I have yet to find anything that justifies those measures in an above ground pool, especially in a real world scenario.
As I said, 60 electrical deaths in 13 years, most if not all is due to lack of GFI or fault GFI and people using appliances in or around their pool (radios and such). Why add more to an electrical code that was already effective?
The more I deal with codes, the more of a libertarian I become.
1> One hammer tap at a time.
2> IDK, but it does. At least, it has IMX.
You can use a hammer drill to install a ground rod. They make holders for that purpose but you can just chuck it in the drill. Example Ground Rod Driver | Milwaukee Tool
Received 0 Votes
Thank you Ray. I will get one when that time comes. In digging my trench I ran across the grounding rod (two, in separate places) for my service and another for, well I haven't figured that out, I think the AC unit.
They were steel. I am wondering if I need to go with steel vs copper due to how hard the earth is. Well see.
Nashkat1, I appreciate the advice. The vast majority of codes make sense, some due not. In this discussion I specifically question why I need to bond an AGP that has no exposed metal.
In digging my trench I ran across the grounding rod (two, in separate places) for my service and another for, well I haven't figured that out.
