GFCI outlet keeps tripping
Old 06-27-13, 02:37 PM
K
I have a gfi outlet in my garage that keeps tripping , it will reset and last a day roughly. What I know that is on this gfi is 3 outside outlets, and 1 outlet in basement. Nothing is plugged into any of these things when it trips. I did have a freezer plugged into the one downstairs , and it ran fine for about a week before I noticed it was tripped. The house is about 4.5 years old. Does my gfi outlet need replaced ?
Old 06-27-13, 04:12 PM
ray2047's Avatar
Received 14 Votes on 12 Posts
You need to open the outside receptacles and look for moisture.
Old 06-28-13, 03:22 AM
chandler's Avatar
Received 9 Votes on 8 Posts
While you are checking make sure all the exterior receptacles have approved weather proof boxes and code bubble covers. Otherwise you will have found your problem x3.
