How to turn a sharp 90 with electrical conduit
Old 07-01-13, 06:15 PM
A
I have 1 inch conduit that I am bringing into the building with a pull box. It enters the cavity between 2x4(s) right below the Main panel. I need to take a sharp turn up and go another 2 to 3 feet into the panel.
Can I use a regular PVC elbow to do this? I cant find a 90 degree elbow for 1 inch conduit. There is a 90 degree pull box, but I cant find that in 1 inch either.
Isnt electrical PVC exactly the same as regular with the exception of color?
Old 07-01-13, 06:34 PM
Received 2,680 Votes on 2,432 Posts
You would need to use a 1" LB . Sometimes two back to back to do what you want to do.
Old 07-01-13, 06:35 PM
Justin Smith's Avatar
Received 1 Vote on 1 Post
You can use a LB (pull box) if it's going to be permanently accessible. Otherwise you're sol.
No. Electrical PVC is free of sharp edges and turns, contains fire retardants, stabilizers, and has a UL, ETL, CSA, or other NRTL listing making it suitable for electrical.
Old 07-01-13, 06:49 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
Or a pull ell:
[ATTACH=CONFIG]14621[/ATTACH]
Image source: Galesburg Electric
Old 07-01-13, 08:09 PM
A
Ray, I cant find one of those in 1 inch.
Old 07-01-13, 08:16 PM
A
I guess there is another solution, which I didn't like at first, but....
I could bring it right into the back of the box. There are a number of cutouts on the bottom.
Would this work?
CANTEX Pull Elbow, 1 Piece, 3/4 In, PVC - Conduit Fittings - 4FYV9|5240101 - Grainger Industrial Supply.
CANTEX Reducers, 1 Piece, 1X3/4 In, PVC - Conduit Fittings - 4FYK1|5142221 - Grainger Industrial Supply
It has a plate, so does that mean it HAS to be accessible (cant sheet rock over it)?
Old 07-01-13, 10:11 PM
Your link shows a 3/4" pull ell and a 1" to 3/4" reducer.
So that pull ell is too small and that reducer is of no help.
I don't think they make pull ells in PVC larger than 3/4"
.......and yes......any plate on any electrical box must remain accessible.
Old 07-02-13, 06:28 AM
ray2047's Avatar
Did a search and I retract my suggestion. Just didn't occur to me there wouldn't be. Live and learn. Shutting up now.
Old 07-02-13, 07:54 AM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
Would a 1" metal pull ell with two PVC male adapters work in the space?
Old 07-02-13, 10:40 AM
P
Is it possible to set the exterior LB at an elevation equal to the elevation of the panel , so the conductors enter thru a KO on the back of the panel ?.
Old 07-02-13, 03:12 PM
CasualJoe's Avatar
Received 152 Votes on 135 Posts
This is a good way to do it, but I would prefer using a 90 degree elbow like this:
CANTEX 90 Elbow , Schedule 40, 1 In, PVC - Conduit Fittings - 4FYE5|5133825 - Grainger Industrial Supply
Old 07-02-13, 04:21 PM
Nashkat1's Avatar
I agree. Much easier to pull through.
Old 07-02-13, 05:00 PM
pcboss's Avatar
Received 141 Votes on 125 Posts
See if a commercial electrical contractor will bend one for you or check a supply house for the 90.
