Wire Nut Reamer/Cleaner
No, that's not a misprint, I'm actually asking about such a thing... it apparently doesn't exist.
Why not??? With all of the useless crappy doodads and whatchamacallits these days, you think someone would have hit on the idea, or am I just that insane?
New nuts, I don't really care, but is it not common to have nuts on old work break off? Yes, I do save them.....
It's real common for wires to break off in old wirenuts. Never found a way to remove them though.
I used to use extra-pointy needle-nosed pliers to get old wires out of them. But then I realized that my time is worth more than the few-cent wire nut. Also, I'm part of the disposal generation. I like everything I work on to be clean and new. It's occasionally a character flaw
Many times re-using a wire nut doesn't result in a tight connection. They loosen for whatever reason, and I wouldn't trust them with a current-carrying circuit that's close to the wire rating. The few cents you save could cause thousands of dollars damage due to fire.
Ideal 71s and 74s
That's about exactly how old they are, too.
