What's acceptable to bring wires through lap siding?
Old 07-15-13, 10:51 AM
Over the years I've seen wires for outside receptacles, porch lights, etc brought through wood siding done several different ways:
Leave the box in the stud bay & bring wire tails out through a hole in the siding, screwing the fixture to the wood itself.
Install box extension sleeves so the wood is "lined" with steel.
Rip out the old box (if possible) & install new (usually plastic) boxes in the siding (but sometimes the clamps won't grab thick wood siding).
Leave the old box, bring the wires through a hole & mount aluminum surface boxes (yuck).
Is there more than one way to do this so it's to code?
Extra credit--What do installers do with vinyl siding over 2" (or more) foam to get a solid mount for fixtures & sillcocks?
Old 07-15-13, 07:55 PM
Not to code.
Code acceptable.
Better to use metal cut-in gem and screws thru the ears to the wood.
Not to code.
Personally I remove the old box, if possible, and install new box in the new wood siding. I don't allow the carpenters to cut my boxes in. I leave a tail that they run thru a hole and I cut my own.
For thicker siding.....use longer screws.
Old 07-15-13, 08:01 PM
pcboss's Avatar
Look at the siding boxes from Arlington.
Aifittings.com
Old 07-15-13, 10:23 PM
Justin Smith's Avatar
Fortsner bit and use a pancake box, otherwise use a siding box from Arlington. Where I need to attach stuff like a photocell, I'll put a cut-in box inside and run 12/2 or 12/3 outside and use a surface box mounted to a siding plate painted to match.
Old 07-16-13, 10:59 AM
I'm trying to picture what you mean. Bore a hole large enough to surround the 4" round box? Screw down over the old box?
I have an follow-up question about the code-acceptable box extension sleeve. Is it OK then to screw the fixture or receptacle directly to the wood siding--the important thing being that the wires are contained "inside" the steel box?
