Stripped bakelite box screw hole
Received 0 Votes
Any trade secrets to repair stripped out receptacle mounting screw hole in an old bakelite box?
Some epoxy like J-B Weld...pushed in to the hole...then put the screw in. Spray the screw with silicone or similar (wipe most off), let the epoxy set and the screw should come right back out.
Or a slightly longer self tapping screw...lol.
Agreed, Nashkat1. Bakelite has absolutely no "give" so it will almost certainly break if you try to use a screw with a larger diameter. I've used a small sliver of wood with decent results.
Never tried the JB Weld. Sounds like a plan.
Received 0 Votes
Thanks guys,
When I posted I subscribed to thread but didn't change the method and was wondering why I hadn't got any replies.
Anyway, great ideas. I'll give the epoxy and silicone a try. I was considering epoxying a nut to the face of the box. A longer screw won't work as it is a thru hole.
