Running electricity from my house to a large shed for an office
Hello my name is Michael. I am having a 12x32 wooden shed delivered to my house tomorrow. I am going to turn the shed into a home office/livingroom. I am putting the shed as close to my house as I can. The shed will be about three feet away from my home and about 6 to 8 feet away from my outside breaker box. I have a large breaker box outside with 1 main quad breaker and three double breakers so I'm assuming that I have space available for at least 1 double breaker. In the shed I'm going to want at least two over head lights one of which I would like a ceiling fan. I also would like an outlet on each wall and two total on each long wall so a total of 6 outlets. I am going to be using the outlets for my computer, tv, maybe lamps, stereo, vaccum, ext. Pretty much the essentials that you would use everyday in your house. I also will need to heat and cool the building and need to either use a window unit or a wall unit of some sort. I also would like an outside light by the door and a total of two or three light switches in the building. Depending on the price it would also be nice to have an outlet on the outside of the building. I have called about 8 electricians and the prices I'm being quoted are dramatically different. Ranging from $600 to $2000. Why are The prices so different? I need to know what to look for what questions to ask the electricians and what exactly I am going to need. Will I be able to connect to my existing outside breaker box, will I have to bury wires or can they be connecting without digging, do I need a breaker box in the shed, what price range should this job be, ext? I feel that some of these electricians around here just want to rip me off because I don't know anything about electricity I need some help and advice thank you. Michael p.s. I am located near Murfreesboro TN
Welcome to the forums, Michael.
I used to live in Murfreesboro but, since I've moved to Virginia, I can't come give you a quote. I'll just have to be one of the advice voices.
First of all, what do you mean by "a quad breaker?" Second, what you can add to your existing panel depends on both the spaces available and the size of your service. Tell us what those conditions are.
The two 32' walls will require at least 3 receptacles each. You will need 2 receptacles on each of the 12' walls. That's 10 or 11 receptacles total. I would figure 2 20A circuits for those.
You need to decide what you will use for heating and cooling before the proper size of the panel can be determined, since those will be your heaviest loads.
That depends on your answers to the questions above.
Buried conduit would be best but there are other options. It depends on the look you want, the relative location of the existing panel to the new building, and your local permitting authority. Rutherford County?
Yes.
Can you post a picture of this box?
Biggest mistake people make when doing this job is not supplying enough power to the building and using undersized wire thinking there saving money.
A whole lot cheaper in the long run to not undersize it so it does not have to be all done over.
