Help Adding Sensor light to Garadge Wireing
Old 07-20-13, 09:40 AM
Hello, and thank to anyone who will try to assist me.
My garage keeps getting broken into so i need to put a sensor light in the back on the outside. There is currently one electrical wire coming in which goes to a light switch then to the light inside the garage.
I just want to confirm that I can tap into the wire before the light switch and run a line to the back of the garage, to a switch (to control the sensor light) then to the sensor light. Attached is 2 visual aids so you can kinda see what i need.
And if this is possible do i just put in a Junction box and do the tap in wiring in there. DO the junction have to be a certain distance away from the indoor light switch? Or can i put it right under on the 2x4, ( there is no drywall or anything, framing is all open)
I live in Canada, saskatchewan
Size:  8.6 KBName:  idea.jpg
Old 07-20-13, 09:57 AM
Welcome to the forums.
You can take power out of the first switch junction box to run the second light. You could also change the single switch box to a two gang box and put both switches there.
Old 07-20-13, 10:35 AM
It is perfectly acceptable for the romexs to be next to each other for the two different lights.
