220 VOLT WIRING
I have a 220 volts 20 AMP air compressor, which i need to temporarily wire from my home instead of my garage, (which is being built, and has no electrical outlets at this time).
I was planning to use an un-used stove outlet which is 220 50 amps, (i'm going to replace the breaker to a 20 amp). The problem is: the stove outlet is 4 wires; (one black, one red, one bare ground, one white). I believe the black and the red each have 115 volts in them. The compressor is a 3 wire. Which wire gets left out of the equation to hook up the compressor? I need the compressor to complete the garage!
Received 0 Votes
Between the red and white is 110 v
Between the black and white is 110v
Between the black and red is 220 v
bare wire for grounding to electical box and to the grounding screw of plug (possibly green)
So BLACK AND RED give you 220 v , if the white is not used cap it with an insulator nut. What color is the 3rd wire for the compressor, green is a ground wire.
Thanks for replies, but it didn't work...
Received 0 Votes
If you connected the black from the compressor to red and black , you created a dead short, and of course blew the breaker. If you are certain that the compressor is 220 volt and there is no 110 usage here at the compressor, I have to take your word for this. Then black wire from compressor to black , and the white wire from compressor to red, ground to ground. When I said black and red gives you 220 v, I didn't mean you short them together to get 220 v. If only 220v is being used , the white/neutral from the circuit power is not used. White is known in north america as a neutral wire , but if only 220 v is being used at the compressor (no 110 usuage) and if black/white are the only wires coming from the compressor (besides the ground) then logic says they must be the 2 wires used to feed 220v to it.
[Edited by dkerr on 02-25-01 at 01:08]
