Dishwasher - 2002 NEC - requires disconnect or not?
Old 07-22-13, 12:44 PM
Search Engine Optimized Spammers Not Allowed!
Hi,
I'm getting different information about whether a dishwasher electrical connection requires the ability to disconnect the power (either via a switch, or via a power cord plugged into an outlet).
Our village follows the 2002 NEC.
What is the rule per that code?
Thanks!
Old 07-22-13, 01:31 PM
pcboss's Avatar
If the unit is hardwired a means of disconnect is required. This can be a lockout bracket installed on the panel door.
If cord and plug connected the plug is allowed to be the disconnect.
Old 07-22-13, 01:51 PM
Thanks -- what would the lockout bracket installed on the panel door consist of? I've got someone doing the wiring for the DW -- would that be something he does, or ?? Currently the hardwire flexible conduit is coming through the floor behind the DW. Is there one way that is better/easier than another, given what was done thus far? Thanks
Old 07-22-13, 02:26 PM
pcboss's Avatar
Here are some examples of a lockout. You need one that will accept a padlock.
https://www.google.com/search?q=brea...w=1151&bih=706
Sounds like your unit will be hardwired.
If a cord is used the DW needs to be listed for a cord and the cord also needs to be listed.
Old 07-22-13, 02:35 PM
Thanks for the information!
Old 07-22-13, 03:09 PM
Nashkat1's Avatar
I prefer to mount a switch above the counter. Easier, simpler and clearer than the panel lockout. The switch can also be mounted in a base cabinet - usually inside the sink base.
Old 07-22-13, 04:55 PM
Ok - thanks -- and if he has the direct wire coming in from the floor behind the DW location right now, how hard would it be to put a switch in the sink base cabinet (which is already installed)?
Thanks!
Old 07-22-13, 06:39 PM
Nashkat1's Avatar
IDK. It depends on how long the wire is, what the cabinets are made of, what is in the way under the sink, etc.
Old 07-22-13, 08:53 PM
pcboss's Avatar
Certainly worth asking the electrician what can be done without a lot of extra time and expense.
