one 3-way switch to two 3-way switches (possible?)
I am trying to see if it is possible to have one 3-way switch at the top of the stairs connected to two 3-way dimmer switches at the bottom. I want to be able to control both sets of lights from the one 3-way switch up top, while being able to control them individually from dimmers downstairs. Is this even possible? If so, could someone hook me up with a wiring diagram or description of how to do it? because I can't find anything.
Thanks.
Thanks.
Welcome to the forums.
I don't think what you want to do is possible. If you have all three sharing the switching duties and the two downstairs are both pushed....... the upstairs one can't shut the circuit off. Now you'll have to figure which one to turn off. Very confusing.
You may be over-engineering this. Do you actually need 3-way control? What if you took the power from the panel to a regular on/off switch at the top of the stairs and then to two on/off dimmer switches at the bottom? Then you could control each set while you were downstairs and cut both off as you left the basement at the top of the stairs. Would that give you what you want?
To make it right you'll have to use two 3way switchs and 1 four way switches,, this will require running 2wires from the 3way swith to the 4way switch and another 2 wires from the 4way swich to the last 3way switch. This way all the switchs will control the light..
