2014 GFCI Changes
Old 07-30-13, 01:22 PM
T
Received 3 Upvotes on 3 Posts
2014 GFCI Changes
Will the dedicated dishwasher circuit,,next year,be required to be on gfci anyway.and the dedicated laundry circuit too?
Note this is not the 2-20 amp gfci,-seperate dedicated countertop circuits.which can't be used for disposal/dishwasher .
Old 07-30-13, 04:49 PM
pcboss's Avatar
Received 167 Upvotes on 146 Posts
I have seen that the DW will require GFI protection under the 2014. I don't remember seeing anything about the laundry other than AFCI.
Old 07-30-13, 06:01 PM
T
Isn't it already required that a dedicated line to the dishwasher be GFCI protected at either the wall outlet or the electric panel? Or is that 2014 proposed changes?
Anyways, I think it would be a good idea to have a GFCI protected circuit breaker for a dedicated line to the dishwasher. Do you agree?
Old 07-30-13, 06:25 PM
pcboss's Avatar
Kitchen countertop receptacles have required gfi protection for many years. Dishwashers do not currently need gfi protection. That is changing with the 2014 NEC.
I don't see the need for the change.
Old 07-30-13, 06:39 PM
ray2047's Avatar
Since DW and GD often share does that mean GFCI by the default even if not required when a GFCI breaker is used or will GD also require a GFCI regardless?
Old 07-30-13, 07:05 PM
pcboss's Avatar
Don't remember seeing anything about gfi and gd.
Old 07-30-13, 07:18 PM
Tolyn Ironhand's Avatar
Received 705 Upvotes on 598 Posts
Laundry receptacles are required to be GFCI protected under current code if they are within 6' of a sink.
Old 07-30-13, 08:22 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
Any receptacle within 6' of any sink must be GFCI protected. Mop sink, slop sink, laundry sink, kitchen sink - makes no nevermind.
Old 07-30-13, 08:31 PM
T
The new 2014 changes will apply to all laundry rooms reguardless of sink ..
New 210.8 (a) (10)
Found a excellant link via IAEI..so many changes ..
Old 07-30-13, 09:21 PM
Received 3,480 Upvotes on 3,125 Posts
Re: 210-8(D)
This would include a receptacle outlet or a hard wired outlet for a dishwasher.
Not too confusing. Hard wired circuit would be a more appropriate description.
Old 07-30-13, 10:16 PM
Nashkat1's Avatar
I like that they used "hard wired outlet." It makes it clear that "outlet" is not just another word for "receptacle."
At least not to the folks who update the NEC.
