Reload this Page >
How to wire an outlet so its incoming power is controlled by a switch?
Old 07-31-13, 08:16 AM
How to wire an outlet so its incoming power is controlled by a switch? I am taking a guess here:
Wire an outlet as if it was a light fixture.
Is that correct?
I want to be able to control a plug-in appliance (small fan) with a switch.
Thank you in advance!
Jeff
Old 07-31-13, 09:29 AM
ray2047's Avatar
A light is an outlet as is a receptacle which is what you are installing. Yes, all outlets are wired the same either using a switch loop or if power comes to the switch first a switched supply to the outlet.
Old 08-01-13, 07:07 AM
Old 08-01-13, 08:43 AM
This diagram is awesome! Thanks so much!
