Range Breaker.
Old 08-01-13, 07:21 PM
Range Breaker.
Hello all.
I decided today I was going to move the range for my wife to make better use of the small living room. I went down stairs to check out how hard it would be to run the 6/3 wire; I checked my breaker and its a 100AMP!!!!! breaker connected to the range. The whole house only has a single 100amp breaker box.
This worries me as I am almost sure that at that size if the wire shorted it would catch fire before tripping the breaker. I looked all over my range and can't find any model or part number that I could use to look up the manufactures recommended breaker. I was thinking replacing the breaker with a 50 amp breaker, does that sound like a safe bet?
The total wire length will likely be 15 - 20 feet depending on how straight I can run it. The range is low end flat top GE your standard 4 burner unit nothing fancy.
Thank you.
Old 08-01-13, 07:30 PM
Tolyn Ironhand's Avatar
Welcome to the forums!
Yes, a 50 amp breaker should work just fine.
