Hot ground wire?
Old 08-07-13, 06:47 AM
Hot ground wire?
Separated from: http://www.doityourself.com/forum/el...ound-wire.html
Hello everyone,,
As strange as it may seem it is true there are ground wires that are hot,,,
I used a tester,one side touching the hot and the other side touching the water pipe I have 110volts,,,then touched the gas pipe in same sequence ,, 110 volts again but neutral to ground nothing,,,am working on this problems as I write,,have a great day I'll be back in the afternoon and post what I find...
Old 08-07-13, 07:31 AM
Welcome to the forums.
You will see 120v from hot to ground.... whether that ground is a water pipe or gas pipe.
You should never see voltage from neutral to ground.
Technically they are at the same potential and from neutral to ground is a dead short.
