Need some help with this generator
Hi everyone, I am a new member to this forum. My reason for being here is to find some help with an old generator that I have. I am also willing to share my limited knowledge with others as much as possible.
the picture below is the generator. problem it is only producing 3v ac. need help pleasr
Welcome to the forums from Jamaica.
It doesn't look like a model that most of us in the States are used to seeing or working on. A make and model ...... or at least a make ..... would be a start.
Your power is similar to ours except yours is 120v at 50cycles.
Most generators are protected by a circuit breaker or GFI. Have you checked that first ?
If the motor is running and you are not getting output from the generator it's field coil may have lost it's magnetism and need flashing but first I would look for any type of circuit breaker or overload protection that may have tripped. There are many sites on the web that have detailed instructions how to flash a generator.
