Moving electrical box
Old 08-09-13, 04:16 PM
I have a light just above the mirror in the bathroom. I need to have an electrical box higher to accommodate a new fixture. The existing feed is from above in thinwall conduit (EMT). How do i do that?
Old 08-09-13, 04:22 PM
ray2047's Avatar
The existing feed is from above in thin wall.
Did you mean the cable comes from above? If so just put an old work round box above it.With luck there is only one staple and you can remove that from the opening for the new box or you may not even need to remove it.
Old 08-09-13, 04:32 PM
I am saying that the thin wall feed will be in the way of the new box.
Old 08-10-13, 06:55 AM
CasualJoe's Avatar
You will have to shorten the thinwall conduit to accommodate the higher box position. Probably will have to open the wall. Just part of the make-work politics in parts of Illinois.
Old 08-10-13, 07:15 AM
pcboss's Avatar
Is the wall thin or is this actually a conduit system?
Old 08-10-13, 11:53 AM
the house is wired with thinwall conduit
Old 08-10-13, 12:18 PM
ray2047's Avatar
Wish you had said EMT or thin wall conduit. I was totally guessing at what you wrote.
Old 08-10-13, 01:22 PM
Nashkat1's Avatar
Can you get to the upper end of this piece of pipe and loosen it so you can pull it out to cut it, or do you need to cut it in place?
I'm curious. Why do you need to add a second outlet above the one you have now?
