Wiring Terminals
Old 08-10-13, 11:55 AM
kolias's Avatar
Received 7 Upvotes on 7 Posts
Wiring Terminals
Don’t know very much about electrical but for my new CNC control panel I was thinking to use DIN rail / terminals which I cant find locally but I found the attached strips (don’t know how you call them) which I think they will do the same job
These strips are marked 450V and one is for 12mm square wiring and the other is for 8
Besides that the DIN terminals may be more convenient, do the strips on the attached picture perform the same function? Means you can join 2 or more wires together?
Old 08-10-13, 02:36 PM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
I think those are called barrier terminal strips.
Excellent choice for connecting wiring in machinery. They make perfect splice blocks for temporary or permanent wiring connections. I also use them in large size alarm installations.
Terminal strips | Electrical Connectors
Old 08-10-13, 03:20 PM
kolias's Avatar
Thanks PJmax, I will use them too
