DIY Hot-Box?
Old 08-10-13, 10:05 PM
Justin Smith's Avatar
Received 1 Vote on 1 Post
DIY Hot-Box?
I am going to be doing a lot of PVC work this upcoming week and would like to use a hot box. Problem is, they run almost $700 which is quite a bit. I've heard of people making their own, has anyone tried this or have any good plans? I've heard of using lightbulbs.
Old 08-10-13, 10:50 PM
ray2047's Avatar
Received 14 Votes on 12 Posts
Probably not what you had in mind but maybe a start. I'm thinking a fan (might not need a fan) and heat lamps in porcelain keyless sockets instead of heat guns. Maybe a drill and fan speed controller instead of a motor. Maybe use pulley ratio to get the drill speed down.
http://www.youtube.com/watch?v=aZ4U7XdTIFQ
Old 08-11-13, 05:11 AM
Andrew's Avatar
Received 14 Votes on 10 Posts
Perhaps you could rent one??
Old 08-11-13, 06:20 AM
CasualJoe's Avatar
Received 152 Votes on 135 Posts
What size will you need to bend. I think a blanket works just fine with up to 1" PVC Sch 40 conduit.
Gardner Bender Hotblanket PVC Benders - hot blanket pvc bender .5-1.5'': Tools : Walmart.com
Link says up to 1 1/2"
Here's another one, this one says 2" to 3", but still a bit pricey.
Hot Blanket PVC Bender for 2"-3" Conduit at Menards
Old 08-11-13, 08:36 AM
Received 2,670 Votes on 2,422 Posts
You didn't mention what diameter you'll be working with.
The only problem with heat bending is time spent waiting for the pipe to heat and then for it to cool.
I have both a heat box and blanket but many times I'll buy the pre-bent fittings for speed.
Sometimes I'll use a heatgun for a quick bend.
Not sure how effective lamps will be.
Old 08-11-13, 08:58 AM
I will be using 1/2, 3/4, and 1''.The reason I need to bend some of these myself is because there's a lot of "odd" shapes that I need to go with.
Old 08-11-13, 07:43 PM
CasualJoe's Avatar
For small conduit like that, I'd forget the hotbox and go with a blanket. OR, the poor mans bender, a propane torch.
Old 08-11-13, 09:03 PM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
You have to heat the pipe evenly. That's why the factory hot boxes have linear heating elements and a pair of rollers at each end - so you can rotate the pipe.
I'd go with a blanket or a torch with a fan tip, like Joe said, unless you have several hundred feet to bend.
Old 08-14-13, 10:25 AM
Nick D.'s Avatar
The MAPP torch is one of my most frequently-used tools. With a fast and coordinated hand, you can do things with it that might be surprising.
The intense flame applies heat generously, but without scorching or burning when kept in motion. If you rotate PVC at a few revolutions per second, a blasting torch flame will heat it in a few seconds.
For rotating the pipe, by no means do you need anything as complex and overbuilt as the rig in the video.
You don't even need an expensive motor...
If you want to DIY your own version of a $700 hotbox, you can do that too...
Starbar Silicon Carbide SiC Heating Elements On I Squared R Element Co., Inc.
Old 08-15-13, 06:00 PM
I've been using the MAP torch from the workshop for the past few days. Looks like I'll be doing that for awhile. I put a thermal blanket on my Christmas list.
