What wire to run to a kitchen range?
Received 0 Votes
I am doing a home kitchen remodel and haven't decided on the type (gas, electric, or dual) of stove/oven I am going to put in. However, I do want to run the electric wires before deciding so that I am covered in case I change my mind later on.
I was thinking of running either a 8-3 electric wire or a 10-3 electric wire. What gauge of electric wire should I run to cover all my bases?
Unless you plan on using a commercial type range an 8-3 copper with ground should be sufficient. You also want to run a 120 volt receptacle for a gas range light and ignitions system. This 120 volt circuit may come from one of the required small appliance branch circuits.
You should at the very least run an 8-3 NM w/grd. That would give you a 240vac 40amp feed.
If you go with a monster range......some require 6-3w/grd.
Received 0 Votes
Ok, thanks for the recommendation guys. Yes, so I think I'll just run an 8-3 wire.
On a separate note, I'm also going to do an overhead microwave with a built-in vent. Do you think I'll be ok with a 12-2 electrical wire with a single pole 20 amp breaker at the outdoor electrical panel?
