DIY Hot Wire Styrofoam Cutter Help (AC current)
Received 0 Votes
I'm trying to build my own hot wire cutter for cutting and shaping styrofoam. I have this AC cord that I stripped and split the two end wires:
I'm using a guitar string (the third from the top) for the wire that is to be heated.
I touched the two ends of the AC cord to the two ends of the guitar string, plugged it into an outlet, and nothing happened. What am I doing wrong?
Welcome to the forums.
The principle is simple.....it's called a hot wire cutter. You've probably already seen/used one.
In your picture you're using what looks like a 20vdc 1.8amp computer switching power supply. No good. When you connected the guitar string to it you created a dead short on it and it shut off.
You need a power supply that can run into a dead short or is good for several amps. In the videos below they show you what they use. The first video the guy uses a power supply with a dimmer for varying the voltage. Probably a good idea. The second guy uses an actual desktop computer supply which seems to work ok.
DIY Hot Wire Cutter - YouTube
DIY Foam Cutter on the Cheap - HOT WIRE! - YouTube
