Replacing Receptacles
Old 08-21-13, 03:54 PM
So I want to replace the receptacles in my new home. I'm pretty sure they've been here since it was built in '85. It seems like a pretty simple task, except that the wires are going directly into the back of the current receptacle and I can find no hole where you can supposedly release the wires and pull them out. Is it possible to just cut the wires and do it that way?
Old 08-21-13, 04:14 PM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
You can cut the wires provided you have enough to work with.
There should be a small squaresh hole right next to where the wire pushes in. That's the release hole where you would put in a very small screwdriver or punch.
Old 08-21-13, 04:24 PM
ray2047's Avatar
Remember those back stabs can be unreliable. Use only the screws when you install new ones.
Old 08-21-13, 04:27 PM
Thank you. Much appreciated.
