Garage GFCI Keeps Tripping
Received 0 Votes
I have a GFCI in the main outlet in my garage. There is a Garage Door Opener (GDO) plugged into the only outlet downstream from the GFCI. It has been working fine for the past few years but now the GDO trips the GFCI whenever it's plugged in. It doesn't trip the breaker, just the GFCI.
I've tried replacing the GFCI and it happens again immediately with the brand new one. Current is never restored long enough to trip the GFCI, it just immediately dies. Cannot be reset, either. Bypassing the GFCI, the GDO works just fine, and the outside garage lights (motion sensor activated) suddenly work again when they haven't for a couple of years.
Is there a way to not have the GFCI trip? Like I said it worked just fine for the last 4-5 years. Thanks.
If the GFCI does not trip with the GDO unplugged and the lights on You probably need a new GDO. The GFCI is just doing what it is supposed to do. You can double check by running an extension cord from a different GFCI circuit and if that circuit trips it is the GDO.
It sounds like the GFCI is doing what it's designed to do and you have a ground fault in your GDO. I would plug a work light or a shop vac or some other decent load into the receptacle for the GDO to see if the GFCI would hold for that.
