Freezer light burning out
Old 08-24-13, 01:23 PM
jps
jps is offline
Why would my 3 year old freezer bulb keep burning out. Using a 40 watt, 125 v appliance bulb. This is the bulb to light interior of freezer. TIA jps
Old 08-24-13, 01:29 PM
It could be a case of marginally high voltage in your home. Look at the light bulb to see what the rated voltage is, often it is 120 volts which is the nominal voltage in your home. For a couple of reasons your voltage may be higher, even as high as 132 volts. Look for a bulb rated at 130 volts for the refrigerator.
Also, do other light bulbs in your home seem to have a shorter life than you think they should?
Old 08-24-13, 01:34 PM
jps
jps is offline
Other bulbs are working fine. Where would I find a 130 v appliance bulb? TIA jps
Old 08-24-13, 01:44 PM
Nashkat1's Avatar
Never touch a new bulb with your bare skin when installing it. This is especially important for incandescents and halogens, and more so when those bulbs will be in a cold environment. The ides is to not leave an oily fingerprint on the bulb, which can create a hot spot.
What is the manufacturer's recommended type and size of bulb for your freezer?
Old 08-24-13, 02:20 PM
CasualJoe's Avatar
Is the bulb going off when you close the door?
Old 08-24-13, 02:28 PM
ray2047's Avatar
Did you use the same brand from the same store or worse same package? They could be from a bad lot. Once bought a package of bulbs at a good price. Every one of them burnt out in eight seconds or less.... yes seconds.
