surge receptacle
Old 08-28-13, 09:52 AM
surge receptacle
Hello all. Quick question. Does a surge protector receptacle work like a gfi in the sense that every regular receptacle after it will cut out if the surge protector trips? Thanks
Old 08-28-13, 11:35 AM
CasualJoe's Avatar
I don't believe so unless they have changed, I haven't even seen one in a long time. Check out the specs and instructions and call technical support and ask if you don't find your answer.
5280 > Receptacles > Type 3: Surge Protective Receptacles > Surge Protective Devices > Products from Leviton Electrical and Electronic Products
Technical Support: 800-824-3005
Customer Service: 800-722-2082
Old 08-28-13, 04:16 PM
Surge protectors don't trip. It's a shunt element controlling the maximum voltage on a line. They will provide that effect to all recepts on that branch, although long branch wiring runs will not get the full benefit.
Old 08-28-13, 04:33 PM
I use surge protection receptacles on sound installations.
I don't daisy chain receptacles from it. I use one at every location.
