can u put batting insulation in ac wall plugs?
Old 08-30-13, 08:29 AM
ive seen insulation in some exterior wall plugs is this code legal?
Old 08-30-13, 08:50 AM
Nashkat1's Avatar
If you're asking about thermal insulation placed in the outlet box where a receptacle is mounted and connected. If so, no, that isn't compliant with electrical codes. Most insulation is flammable, and shouldn't be next to electrical connections. That's why there's a box.
The space between the edge of the box and the wall can be sealed, and a thin foam gasket that fits over the receptacle and behind the face plate can be installed.
