Range Hood: Junction box Needed?
Old 09-06-13, 12:59 PM
L
I have removed an old range hood. There was no electrical box in the wall. The 12-2 plus ground wire came throught the drywall and wire nuts were used to connect the range hood wiring to the romex. should I install an electrical box in the wall, make all the electical connections inside that box, and then attach the rangehood to the cabinet? Advise.
Old 09-06-13, 02:44 PM
ray2047's Avatar
Yes connections should always be made in a junction box. Sometimes the connection box of the fixture is rated as a junction box.
Old 09-06-13, 03:08 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Were the connections made inside the range hood's box or enclosure?
Old 09-07-13, 02:43 AM
T
Don't some elec contractors just pull the elec wire right through the drywall without junction boxes for things like hard-wired under-cabinet lights and range hoods?
Old 09-07-13, 03:17 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
As the others have mentioned, yes, if the appliance has its own wiring containment system, such as a built in junction box, which most hoods have.
