What type of 240v plug is this?
Old 09-02-13, 11:40 AM
I have to replace a window air conditioning unit and the plug it uses I cant seem to find a adapter for:
Existing wall outlet: http://i.imgur.com/QlHTvjZ.jpg
Plug on old (dead) air conditioner: http://i.imgur.com/wyaKD8G.jpg (this plug is BIG- about 2x the size as a normal plug)
Plug on new air conditioner : http://i.imgur.com/RgZL6Xq.jpg
So, I need the plug on the new air conditioner to go into the existing wall outlet, but cant seem to find a adapter. I would really prefer not having to get a electrician involved to save some money.
Any help?
Edit- It looks like I need a 6-20p to 6-30r nema adapter - But I cant seem to find one online. Where can you get it?
Old 09-02-13, 11:54 AM
Welcome to the forums.
The new plug looks like a 120 volt, 20 amp plug. You sure it's 240 volts?
Old 09-02-13, 12:01 PM
Old 09-02-13, 12:10 PM
That says it's 208 volts....
Old 09-02-13, 12:20 PM
Tolyn Ironhand's Avatar
The link specs list it as 208/240 volt.
You need to change the breaker to a 20 amp breaker, then change the receptacle to a 6-20R. You will likely need a new faceplate. This will likely cost less than an adapter. The wire size should be fine as it will likely be #10.
Old 09-02-13, 01:29 PM
lawrosa's Avatar
Super Moderator
Dont know if it matters but it says 230v not 240v
Voltage / 60 Hz: 208/230
Old 09-02-13, 03:15 PM
Nashkat1's Avatar
Yeah, I saw that too. I expect it's a typo. It shouldn't matter.
208/230 makes no sense. 208/240 - commercial 3-phase / residential single-phase - does.
Old 09-02-13, 04:07 PM
Nashkat1's Avatar
It does at first glance, doesn't it? Took me a second, and a suspicion of what the difference might be, to get it.
In a 120V 20A receptacle, the "T" is on the neutral, or left-of-ground, or clockwise-from-ground, slot. On the plug on the OP's A/C unit, it's the blade for the other slot that's turned flat, or 90[SUP]o[/SUP]. That plug won't fit into a 120V receptacle. It will fit into the 6-20R receptacle that Tolyn suggested.
Old 09-02-13, 04:38 PM
What gave it away for me is the big "6-20P" on the cord cap.
Old 09-02-13, 07:05 PM
Nashkat1's Avatar
Oh yeah. .
