Lights blinking. Blame electric company or breakers?
Received 0 Votes
Hello, every now and then (like today) the lights have been blinking and causing the AC's thermostats to make a rattling noise for a while. It seems the whole house isn't immune to it, but some rooms do it worse.
Should I blame the breakers and get an electrician ? Or call the power company ? They put in a new transformer around a year ago when we got new neighbors.
This sounds like it may be a problem in the panel that is going to take some troubleshooting skills while working in a hot panel. I would suggest calling a professional.
Lighting should not affect air conditioning loads.
Received 0 Votes
I really have no idea what it is. I probably could look later today. We heard no sizzling like when a breaker melted on us and started sizzling though. We still have plastic built up in there from where the hot water heater breaker melted against it.
We were quoted at $600-800 on replacing the whole thing with better breakers.
Received 0 Votes
Your AC unit draws higher amps when the compressor kicks in which pulls amperage away from the light circuit causing lights to flicker.
This can be caused.
By a low amp main breaker, such as using a 100 amp main breaker when the house itself is wired in such as way as to need over 100 amps when multiple 220 volt circuits are used.
By a bad or going bad main breaker, which can be both legs of the breaker or only on one side.
The AC being connected to the same breaker as the light circuits that are affected. Have seen it done in some older houses with small circuit panels.
This can be caused.
