12 volts battery + 12 volts car air compressor
Hi guys. I have this air compressor: B41 lot 109 - MVP Protech 250 psi air compressor
but The only way to make it run is to plug it into a car. Can I buy this battery:
Powerfit 12-Volt 4AH SLA Battery | Canadian Tire
And then wire it to my compressor and it'll make it work? If so, would it drain the battery to much or I can make it run for 6-7 mins at a time for a couple of times? I know this may sound like a really easy question but I just wanted to be sure.
Hey, how do I recharge that thing by the way? ahah
Thanks in advance - Rocknroll911
Welcome to the forums.
That compressor probably draws around 6-8 amps of power. That 4ah battery will only give you minutes of service..... like 1 or 2. The only way to know the exact time is by trying it.
I'm not sure of your application but a lawn tractor or motorcycle battery will give you better short time use. Actually, a 10ah version of the battery you linked to would be better too.
Thanks for the responses. Maybe I'll take Powerfit 12-Volt 12AH SLA Battery | Canadian Tire
Or maybe I'll just buy a normal manual pump like one of those http://www.harborfreight.com/media/c...mage_14815.jpg
Have a good day!
Have a good day!
