Outdoor electrical receptacle question
Received 0 Votes
I want to put an receptacle on the outside wall of my front porch. To get the wire out there and to keep it below the level of the tongue & groove flooring I have to bring it through the sill plate. Sill plate is 3 or maybe 4, 2 x 6's stacked on top of each other. Can I just drill a hole through these and pull my wire through? Or do I need to run it through the sill plate in metal conduit for more protection? Sice the wire is going to be protected from the elements by the tounge & groove flooring is there any reason to use UF wire? I know I need to use a GFI outlet.
Are you originating this circuit run from a basement or from a room in line with your location of the receptacle? If from below, it is usually better to drill vertically through your plates and into the hollow of a stud bay, running the cable to your preferred location. You can seal the drilled holes with fire stop caulk once you have it all done. Let us know a little more about your situation.
Sill plate are normally a single flat 2x on top of the foundation. Band or ribbon boards are set upright on the sill plates and are sometimes doubled. A beam could be 3 or 4 2x installed vertical and nailed together to carry a load over a span. It would help to have a better idea of what you need to drill through.
Received 0 Votes
Oops and Chndler.( I over looked your post) YEs I am originating the circuit from the panel in the basement If I drill horizontal straight through the sill plate I will end up at just about the top of the floor joists. I can't drill vertical though the sill there isn't any room.
If drilling through horizontally puts you at least a foot above grade, all you need is a 1/2" hole for a cable. You can install a weather resistant box, GFCI and "in Use" cover and be done. Silicone the hole where the cable exits to prevent water infiltration. I like to silicone the sides and top of outside boxes just to run water off it all.
Received 0 Votes
thanks chandler. 1 more question. Is UF cable necessary? IT will not be exposed to direct sunlight, rain or show. I suppose its possible snow could get near it but it will be tucked away between the porch floor joists
If it is protected from the elements, UF is not necessary. I am concerned about one statement about it being "tucked" away between joists. Why? You may want to post pictures of what you are trying to accomplish so we can see what you see. http://www.doityourself.com/forum/el...your-post.html
Received 0 Votes
When I say tucked away the wire will be run on the floor joists that support the porch floor. IT won't be out in the open where the weather can get to it. Nor will it be where it can be bumped. I will take some pics & post them.
Thank You for your input
Tim
Tim
I used UF cable. Noticed I need to tighten GFI cover:
Well done!
Sorry for the delay. HEre is what I did. I used UF cable. Noticed I need to tighten GFI cover:
Thanks didn't know there was such a thing.
