additional outlet
Old 02-19-01, 04:59 PM
Guest
I am adding a GFCI outlet in my bathroom and am getting the power from an already existing outlet. Do I connect to the "Line" or "Load" in the new GFCI outlet?
Old 02-19-01, 05:32 PM
Camm, you should really read the instructions that come with the GFCI. But the answer to your question is to hook incoming power to the "line" side. You don't use the "load" side unless you have other downstream outlets.
Old 02-19-01, 05:59 PM
Guest
thanks....but it was a faulty GFI outlet...
