spair breakers
Received 0 Votes
Had a question on panel spair breakers,is it important to place them in lowest area of main panel and does it have to be on both sides if you have two or can they both be on side i have open space on.
Also wondered if on inspection will they ususally remove panel cover.i have a sticker on inside panel with nec 1981 verification on it and want to be sure thats seen.my panel was built in a bathroom area so im unsure how it will do on inspection.the box looks great compared to original set u.I'm still making the panel Id chart.
Any info is appreciated
The important thing is no removed knock outs that have neither a spare breaker or a blank filler. There is no requirement to even have spare breakers in a panel. If there are location doesn't matter.
Like Ray said.... as long as all open spaces in panel cover are filled it doesn't make any difference where the spares are.
That 1981 sticker doesn't really mean much either.
Inspection ?? Home inspection or electrical inspection ?
The fact that the panel is in the bathroom will raise some concern.
BTW, it is spare, not spair.
Panel is in bathroom behind toilet.Original panel.
