no power to circuit, breaker not flipped
Received 0 Votes
I flipped the breaker while I was switching out a broken switch for a new one. When I flipped the breaker back, I had no power to the entire circuit. I tried flipping it a couple times, putting the old switch back on, and crying. None of which helped.
I flipped the breaker off for now for fear of a fire or something, but don't know what to do next. There aren't any big power suckers plugged in, so pretty sure it's not that. Help!
Welcome to the forums.
No crying now
When you replaced the switch.... were there only two insulated wires connected to it or more ?
No crying now
What color wires? What color screws. Was there only one cable with two wires (+G) in the switch box with a black and white wire on the switch (+G)? If so the problem can't be in the switch box. Did you open the light junction box?
Tech Info:
Not related to your problem but just for future information position of screws will vary with manufacturer so wires on any switch except a SPST switch such as you have are connected according to purpose of the terminal (screw) on the switch.
Edit: Below Nash has suggested it may be a three way switch. Above was written on the assumption it was SPST switch not a 3-way. If 3-way I must repeat: "position of screws will vary with manufacturer so wires on any switch except a SPST switch [...] are connected according to purpose of the terminal (screw) on the switch.".
Tech Info:
There were three wires. I connected them to the same places on the new switch.
Did your switch have three insulated wires connected to it, or two insulated wires and one bare ground wire? If it had three insulated wires connected to it, does one of the wires have green insulation?
Have you made sure to turn the breaker all the way off before turning it on?
If you did, try this: with the breaker off, remove all of the wires from the new switch. Separate them and put a small wire nut on each insulated wire. Turn the breaker back on to see if it will stay on and power up the other loads on that circuit.
[SUP]Note 1: Ray types faster than I do.
Note 2: ECHO, Echo, echo...[/SUP]
Mod Note: See edit to post above. Echo, Echo, Echo
Received 0 Votes
Thank you for all the help! I ended up having a electrically inclined friend take a look. Turns out, we had to connect the ground wire and the hot wire so that the switch would go on, and send power to the next room.
- Your friend doesn't know anything at all about electrical systems;
- You misunderstood what was done, or aren't describing it accurately; or
- Neither of you cares whether your house burns down or not.
Originally Posted by ray2047
Sounds like you did something dangerous and unsafe. The connections should be removed immediately.
Good luck. Be safe. Remember that the National Electrical Code is one section of the NFPA (National Fire Protection Association) code.
Let us know what you wind up doing to correct it, please.
