Residential wiring question...
Received 0 Votes
30 year old home. Not had any issues with wiring in the 10 years we have lived there until a month ago. Hope I explain correctly. On one circuit there are 2 outlets and a ceiling fan/light. The outlets and the ceiling fan quit working. The wiring to the outlet and switch all showed there was power using a meter. I replaced switch and outlets. Seemed to fix the problem until yesterday. Quit working again. Still have power behind the outlets and switch. It works again this morning. Loose connections? The breaker never tripped in any part of this....
Any and all help is appreciated.
If you are inserting the wires into the back of the receptacles (back stabs) they need to be move to the screws. All wires nuts need to be removed and replaced with new ones or at least checked for corrosion and broken springs. The problem may be in a receptacle that has no problem but feeds the first receptacle that has a problem. All outlets (switches, lights, receptacles) on the circuit must be checked for problems.
Received 0 Votes
All help appreciated
The wires are on the screws. New outlets and new switch for ceiling fan/light. I will check for more wire nuts and check them. The only one I know of is behind the switch for the ceiling fan.
Thanks
Thanks
Received 0 Votes
For what it might be worth, I have had one GE breaker that was bad or going bad where power would go off to everything in that circuit, but the breaker would not trip.
and have seen it happen in many more than "one" stabloc or Federal Pacific breakers where there would be a brief power outage on the circuit without the breaker itself tripping to reveal the true source of the outage.
I ain't saying that's your problem, just that I have seen it happen.
