Going underground...
Hey All,
So I've grown tired of going back into my shed at night only to step on a rake and rap myself on the head like one of the three stooges. So I'm running power.
I don't like the idea of direct bury cable....don't ask why...I just don't. Fear of something severing the line.
I've decided to run proper PVC conduit back there and I'm already trenched out. No problem except for a sore back.
My question is - given that I have proper pipe, buried at the correct depth over a bed of gravel, can or should I just run regular Romex through or even with the conduit, do I need something more waterproof or beefy?
Code aside here....I'd prefer a bit of over-kill as I don't want to do this again....ever!
Do I go direct bury cable through the pipe or is this a big waste of money?
Thoughts?
Thoughts?
I believe code here dictates that I can use regular romex through sealed PVC conduit as long as i'm below the frost line. I don't know about water. I mean, it's sealed PVC and in the event of a crack it's sitting on 5" of gravel.
It's also not what I'd consider a wet environment....Cold, but not wet.
I'm also not sure I understand the benefit of individual conductors vs grouped wire?
Received 38 Upvotes
It does not matter what you believe or consider, the code is adamant that buried conduit IS a wet environment. You may NOT use any wire or cable that is not listed for wet environment.
Received 38 Upvotes
An answer IS a statement. You need to use a wire or cable that is "listed" (tested and stated to be suitable for the specific purpose by a Nationally Recognized Testing Laboratory or NRTL) for wet environments. You already mentioned type UF cable but the preferred method is to use individual wires with type THWN (or dual rates THHN/THWN) insulation. The individual wires are FAR easier to pull through the conduit so they are preferred over a cable.
What exactly would you use then?
Originally Posted by ray2047 in post #2
Best practice is to use individual conductors such as THWN
OK, Thanks. I did't figure that pulling the cable through would be a big issue. I'll take this advice and get wet rated cables.
I'm guessing I should still group all three conductors before pulling it? I can't see how it would be very easy to pull a second and third wire... Unless I'm missing something?
Stranded conductors pull easier but are tricky to terminate. Solid conductors are a bit harder to pull but much easier to terminate.
Install the conduit with the bells pointing toward the location where you want to set up the wire stand to pull from. Feed the fish tape from the other end.
A piece of 1/2" pipe laid and taped between a tread and a back brace on a stepladder makes a good axle for the wire reels.
How long is the conduit going to be?
There's always time for lubrication....
I wouldn't consider trying to pull more than a few feet without lube. the distance on this is only about 35' but there are two 45 degree bends. I've pulled much farther but only through steel pipe...and never underground, not that that really makes a difference.
I actually laid the pipe today. 1 1/2" PVC. I think it's larger than needed but I'm hoping bigger is easier. Of course I left 2 strands of twine inside to pull cable through.
I see what you mean about staggering the head of the cables to pull them through. Makes sense.
So it appears the solution is 12 ga NMW using separate conductors...
I think I'm going to avoid solid core. Such a pain and I'll never power anything that draws too much.
Thanks all
Thanks all
Yea, that must be a CANADIAN thing!
You had mentioned separate conductors so I naturally thought of THWN. By the way, NMW is a cable and appears to be very similar to UF B cable except that it is only rated for 300 volts to ground. The NEC doesn't prohibit installing a cable in conduit, but that isn't a recommended installation either. I can't say about the CEC. Good luck with your project!
I must admit I'm more comfortable with cable. I just figure it leaves less to screw up.
I don;t get how it can be easier to pull separate wires.
You guys ARE awesome. thanks for the patience. I'm a concrete, wood, welding guy. Electrical is obviously not my strength so I really appreciate all this excellent advice.
Cheers
Cheers
Received 38 Upvotes
THHN, etc is coated with thin nylon. It pulls easier, it's cheaper, it's easier to use. Cable won't get you an advantage, but not an issue, either.
#21
#22
Thanks. To be honest I've only tried pulling separate conductors once before. I wrapped them together. I'm guessing that's what made for it being a pain to pull around corners. Thinking back now, I can see how the wouldn't want to make corners while fastened. It didn't allow them to turn at different radius from one another.
I'm very comfortable with the crimp-on terminal actually. But don't think that's going to be necessary here.
This is all making a great case for using direct bury
