60 amp gfi
60 amp gfi
I have a swim spa that needs a 60 amp gfi with loaded neutral.
The panel is GE. I am told they (GE) dont make one. Will any other brand work?
They sell a re-branded one in a spa panel - GE 60 Amp GFI Spa Panel-UG412RMW260P at The Home Depot
Breaker will probably fit but not legal to pass inspection. Use a separate panel near spa - might also use as means of disconnect within sight.
Midwest (owned by GE) also has both 50 and 60 amp spa panels. Both Home Depot and Lowes used to sell 50 and 60 amp Midwest Spa Panels.
http://www.midwestelectric.com/catalog/pdf/MET018.pdf
Astuff is right, you need a disconnect at the spa anyway so just feed the spa panel with a 60A 2P GE THQL breaker.
