Does this look like copper wire?
Received 0 Votes
It looks like copper to me but I just want to make sure if it is nor not, thanks.
Yes it's copper and that top black wire looks like the insulation is burned and also the copper is corroded as if exposed to water.
Received 0 Votes
Thanks casual. I actually took that picture when I was replacing the non working outlet to make sure I put everything back the right way. (My first attempt at an electrical fix) I bought a new outlet and connected it to the screws a few days ago and I don't plan to use that outlet for the time being. Just moved in a few weeks ago and that outlet blew on my first day here. I feel much better with your explanation. some people at a non electric forum had me scared and suggested I get the whole place checked out ASAP.
Welcome to the forums!
What did that receptacle (not outlet) do when it "blew'? Have you determined any source for moisture into the outlet (the box) and corrected it? Did you trim the combustible material (the wallpaper) away from the box before you replaced the wall plate?
I would use it. The heat will help keep it dry, besides the fact that only using it will test whether it is in good condition now.
Received 0 Votes
I might do that casual.. I know one was fixed by a handyman who did several different things for me. That one had half the outlet out and when he went to replace it there were spider eggs all around it. Big ones like the size of a small jelly bean. I might wait for my father to come in January to help me, he's good with electric and general home repairs, but if I notice a problem I will do it myself sooner.
Received 0 Votes
Thanks Nash. It's a mobile home from the mid to late 70s that's why I wanted to know if it was copper or aluminum,
What happened was when I moved in 3 weeks ago I went to plug something in and my 2 ACs (not plugged into where I was plugging something) that are window units turned off. I reset the breaker box tried again and it went out again. I reset it and tried to plug something in. Then it went off again and I tried to reset the breaker box but that whole side of the house was off. No ACs no bathroom light, no ceiling fans working. For a few weeks I just ran my 5000 BTU AC from a 14 gauge extension cord. I was waiting for the handy man to see when he would be in my area again. As long as I had my kitchen and an outlet in my main bedroom to watch TV and use the computer I was making due.
I decided to replace the outlet myself and when I did that whole side of the house started working again once I was done and turned the breakers box back on. People on a mobile home site scared my into thinking that it was an immediate dangerous situation. and yes the wallpaper is away from any wires.
Received 0 Votes
I think I might buy one of these to check out all my outlets
Prime Products AC Line Meter & Polarity Tester Digital
Or should I get something else. Whatever i get I want something that plugs in if you can suggest something else, thanks.
That's good if you travel and want to keep an eye on power but as far as testing.....
You'd be better served by picking up an inexpensive analog meter like in the link. Can be used for checking receptacles and other electrical problems that may crop up.
Gardner Bender 5-Function 12-Range Analog Multimeter-GMT-312 at The Home Depot
Received 0 Votes
Thanks PJ, I would have to see how to use it first, that other one costs between $25 to $35 depending where online I find the best deal. I just want something easy to use and read that plugs in not something with probes that I have to stick into something.
To trouble with that device is if you come back with a problem we will want results we can trust and will ask you to use a multimeter.
Received 0 Votes
I don't even know what that means ray or how to go about it. The main one I use in the small bedroom is 5000 BTU, the living room one I don't use often and it's 8000 btus. I had a 10000 btu portable ac that I used while I was painting the place, but that's just in my spare room and I don't use it now.
Everyone I know just plugs the ACs into a wall socket. My old apartment has s 12k btu running 24/7 but it had a thermostat that shut itself off and on when it got to the desired temperature.
Please read the addition to my post regarding the tester. As to dedicated circuit means only one receptacle on it. A single AC can draw more than 20 amps for a few seconds when starting. Even after starting it will use half the capacity of a 15 amp circuit. You should definitely never use two on the same circuit (breaker).
Received 0 Votes
Thanks ray. I don't know much about electricity. I don't even know if the bedroom one and living room one are on the same breaker. I know I won't use both at the same time just in case. It's not like I can move the ACs. This old mobile home has mostly crank windows and I had to fire someone to put them in. The living room one has a regular sliding up window, but ti's the only one that I can use for that AC.
Just rewire the receptacles if they are in good condition no need to replace if you can get the wires out*. Be sure to wrap the loops clockwise.
*Try a 4d nail or jewelers flat tip screw driver in the slot next to the hole.
#21
Received 0 Votes
thanks ray. I did see online about putting the loop clockwise, but have to recheck it because I didn't know that when I did it. I was able to just pull the last cable out of the backstab by tugging on it.
#22
Inspect the stripped part of any conductor that was in a backstab for damage from the teeth in the clip, and decide whether to trim and re-strip it or use it as it is.
