3 way switch used on a two way circuit?
Old 09-22-13, 10:42 AM
Norm201's Avatar
Can a 3 way dimmer switch be used on a two way light circuit? If so I just don't need to connect the red wire?
Old 09-22-13, 10:47 AM
Give it a try. You won't hurt it. Not all dimmers work like that.
Old 09-22-13, 11:37 AM
ray2047's Avatar
Terminology note: No two way switches in the U.S. That is the British term for a three way switch. Usually what you are referring to is called a regular switch but that is rather imprecise so I usually call it a single location switch or SPST switch. Even more trivia: A three way switch is SPDT switch.
SPST=Single Pole Single Throw
SPDT=Single Pole Double Throw
Old 09-22-13, 12:04 PM
Norm201's Avatar
Hmm...
We normally refer to a two way switch as having one light and one controlling switch. Hence a two way.
One light controlled by two switches we term as a three way switch or circuit. I've been taught to include the light as a "switch" or one of the elements be it two, three or four.
Old 09-22-13, 12:23 PM
CasualJoe's Avatar
I have never heard that.
What if you have 4 switches and 1 light, what would you call that?
Old 09-22-13, 01:33 PM
ray2047's Avatar
The British are most correct. There are two ways to control the light, one way at each switch. We may say three way because there are three ways the switches can be set, Both up, both down, one up, one down. Oddly Wikipedia claims a SPST switch is a two way switch but many of their articles seem to be written by non Americans. For instance try looking up GFCI and you are directed to the European term RCD. Best to just say SPST for a single location switch and no confusion. Note I have heard some here call a single location switch a single pole switch to differentiate it from a 3-way but a 3-way is also a single pole switch. Now back to our regularly scheduled program.
That is the way it is usually done but it could vary with manufacturer as written earlier by PJ.
Old 09-23-13, 04:20 AM
A 3 way dimmer kit will work fine on a regular single switch location light circuit. Just don't use the remote switch module.
Of course you don't want to use a 3 way kit for this prupose because a single pole dimmer swiitch costs less.
(extraneouls information) More ambiguity on the subject of 3 way circuits. Some 3 way dimmer kits refer to the two modules as "master" and "slave". IMHO the main dimmer module should really be called the slave because it takes orders from the other (remote) module.
Old 09-23-13, 01:20 PM
Nashkat1's Avatar
Allen, if you're saying that the "master" and "slave" labels might make sense because only one of the units can control the lights while the other(s) can tell that one what to do, but that it would make more sense if the one(s) issuing commands was/were called "master" and the one taking orders was called "slave," I concur wholeheartedly.
Drives me slightly nutz when they label them the other way around.
