Quick fix needed for flex conduit
Old 09-23-13, 12:33 AM
R
I snagged a piece of flex conduit in my garage and the windings have separated, slightly, exposing the 12/3 running inside. Is there available a clamp-on patch like they make for leaking piping? I really don't want to have to unwire everything to replace a six foot section of conduit.
Thanks,
REFFI
Old 09-23-13, 02:49 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Can you post a picture of the damage so we can see what you see? http://www.doityourself.com/forum/el...your-post.html
Old 09-23-13, 01:07 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
If it's 12/3 it's cable, not conduit. If the spiral coil of the jacket is only slightly separated you may be able to re-engage them by carefully working it by hand - with the power off.
That said, if this piece of cable is mounted where it is subject to physical damage, it needs to be replaced with conduit for adequate protection of the conductors.
