Please help me wire my sub well pump to my generator
Old 09-24-13, 09:16 PM
We need to wire our well pump direct to our generator. Since we'll only use it occasionally, we are not using a pressure switch, etc.
Our genny is 3000w.
Our pump is 2 wire, 115 v, 1/2 hp, 2 wire.
Our wire is 12 g.
Our well is 100' deep, 20' - 30' head.
I just need to know exactly how to hook everything up.
TIA for any tips or help!
Old 09-25-13, 03:00 AM
Welcome to the forums.
So this well is only used for irrigation and has a submersible pump ?
If it's used for your domestic water then it must have a pressure switch and should have a tank.
Have you ever run the well on the generator yet ?
It may have a problem starting that pump.
Old 09-25-13, 09:50 AM
That's what happened to me. My genny is rated at least 2X what my pump requires but the starting current of that pump with all that heavy water sitting on top of it stalled my generator like I jammed a crowbar in it.
