Electric Stoves
Old 09-24-13, 10:47 PM
Electric Stoves
How many Amps does an electric stove pull? would 8awg wire and a 50 amp circuit breaker work.
Thank You
Hobnobchuck
Old 09-24-13, 11:07 PM
Justin Smith's Avatar
Use a 40A breaker if you use #8, 50A if you use #6. You can use either size you want.
Old 09-25-13, 01:53 AM
Welcome to the forums.
Justin's information is correct.
Most ranges use 6-3 with ground on a 50A breaker. There should be a spec plate on the unit or in the installation instructions if it's a new unit.
If you haven't picked out a unit.... I'd recommend installing the larger wire to be safe.
