GFCI Tripping
Old 09-25-13, 06:37 PM
Angry GFCI Tripping
I recently noticed an outside light not working. I happens to be a a GFCI protected circuit so I reset the GFCI. When I turn the light on it immediately trips it again. I installed this light 3 years ago and have been using it all along. I disconnected the light and checked the wires on it and the wall switch, both appear OK. If I reconnect the light without attaching the ground wires, all works OK. What's causing this problem?
Thanks, Steve
Old 09-25-13, 07:30 PM
CasualJoe's Avatar
Received 192 Upvotes on 172 Posts
You have a ground fault. I suspect the neutral is touching the ground wire somewhere at the fixture.
Old 09-26-13, 06:56 AM
Thanks...I'll check it out.
