Add a ceiling light in a bedroom
Old 09-29-13, 03:58 PM
P
Hi, if anyone could please help me out, I'd appreciate it very much. I'm currently trying to add a ceiling light in one of my bedrooms. There is currently a switch that controls one of the half outlets in the room. There is only one wire coming into the switch currently and the hot wire is the white wire. Please see the attached images for the single pole switch and the outlet which the switch currently controls. As for what I would like to happen, I only care about the switch working for the ceiling light I am about to hook up. It does not matter to me if the outlet works with the switch or not.
I have attic access above, so I know how to run the wires from the ceiling to the switch. I just need some help on how to connect it to the switch. Thanks.
Size:  24.5 KBName:  photo(2).jpg
Size:  31.8 KBName:  photo(1) (Large).jpg
Old 09-29-13, 04:34 PM
ray2047's Avatar
No there is one cable not wire. There are two wires both hots. You have a switch loop. Power comes in at the receptacle.
Just need to replace and rewire the receptacle and run a 2-conductor cable from the new light to the switch box.
At the receptacle:
  • Remove the existing receptacle and replace with a new receptacle that has the tab between the screws on the brass side intact.
  • Connect all of the blacks to a pigtail. (6"-8" length of wire same color and gage.)
  • Connect all whites to a pigtail.
  • Connect black pigtail to a brass screw.
  • Connect white pigtail to silver screw.
  • Connect grounds according to code.
At the switch:
  • Connect whites to each other.
  • Connect blacks to switch.
Old 10-01-13, 06:05 PM
P
I just wanted to reply back and tell you thank you very much for helping me out and correcting my terminology and lack of electrical knowledge. Everything works perfectly now.
Old 10-01-13, 06:21 PM
ray2047's Avatar
Glad you got it. Thanks for letting us know.
